    Samsung Galaxy S7 edge
    Back to Getting started
    How to charge the battery
    You should charge the battery in your mobile phone regularly to ensure that your mobile phone is always ready for use.
    Step 1 of 3
    Connect the charger to the phone socket and to a wall socket.
    Step 2 of 3
    When the battery charging icon is displayed, charging is in progress.
    Step 3 of 3
    When the battery is fully charged, you can remove the charger from the wall socket and your mobile phone.
    1. Connect the charger to your mobile phone
    2. End charging
