    Samsung Galaxy S7 edge
    Back to Calls & contacts
    How to divert calls to COMBOX®
    To receive voice messages when you don't answer a call, you need to divert your calls to your COMBOX®.
    Step 1 of 13
    Press Phone.
    Step 2 of 13
    Press MORE.
    Step 3 of 13
    Press Settings.
    Step 4 of 13
    Press More settings.
    Step 5 of 13
    Press Call forwarding.
    Step 6 of 13
    Press Voice call.
    Step 7 of 13
    The current settings are displayed.
    Step 8 of 13
    Always forward
    Step 9 of 13
    Forward when busy
    Step 10 of 13
    Forward when unanswered
    Step 11 of 13
    Forward when unreachable
    Step 12 of 13
    Key in +4186(area code)(your phone number) and press ENABLE.
    Step 13 of 13
    1. Find "Voice call"
    Press Phone.
    Press MORE.
    Press Settings.
    Press Voice call.
    2. Select divert type
    Always forward
    Forward when busy
    3. Divert calls to COMBOX®
    4. Return to the Home screen
