    Samsung Galaxy S7 edge
    Back to Calls & contacts
    How to answer a call
    When you receive a call, you can either answer it, reject it or silence the incoming call alert.
    Step 1 of 4
    Answer call, go to 1a.
    Reject call, go to 1b.
    Silence the incoming call alert, go to 1c.
    Step 2 of 4
    Press and drag the accept call icon right.
    Step 3 of 4
    Press and drag the reject call icon left.
    Step 4 of 4
    Press the Top volume key or the Bottom volume key when you get a call.
    The incoming call alert is silenced without the caller hearing it, and the call continues until it is ended or diverted.
    1. Select an option
    2. 1a - Answer call
    3. 1b - Reject call
    4. 1c - Silence the incoming call alert
