    Samsung Galaxy S7 edge
    Back to Calls & contacts
    Add fixed numbers
    When you add fixed numbers, you can only make calls to these numbers and emergency calls. Incoming calls aren't affected.
    Step 1 of 11
    Press Phone.
    Step 2 of 11
    Press MORE.
    Step 3 of 11
    Press Settings.
    Step 4 of 11
    Press More settings.
    Step 5 of 11
    Press Fixed Dialling Numbers.
    Step 6 of 11
    Press FDN list.
    Step 7 of 11
    Press ADD.
    Key in the required name.
    Step 8 of 11
    Press Number and key in the required number.
    Step 9 of 11
    Press PIN2 and key in your PIN2.
    Step 10 of 11
    Press SAVE.
    Step 11 of 11
    1. Find "FDN list"
    Press Phone.
    Press MORE.
    Press Settings.
    Press FDN list.
    2. Add fixed numbers
    Press ADD.
    Press SAVE.
    3. Return to the Home screen
