Login/account box
Mobile guides
Samsung Galaxy S6
I can't use tethering on my mobile phone
Cause 1 of 1: Your computer and mobile phone haven't been correctly set up for tethering
You need to set up your computer and mobile phone correctly before you can use tethering.
Solution: Set up your mobile phone and computer for tethering.
Step 1 of 5
Step 2 of 5
Step 3 of 5
Press Mobile hotspot and tethering.
Step 4 of 5
Press USB tethering until the function is activated.
Samsung Galaxy S6
Step 5 of 5
An Internet connection from your computer via your mobile phone is automatically established.
When the connection is established, you can access the Internet from your computer.
1 Connect your mobile phone to the computer
2 Activate tethering
3 Establish connection
Samsung Galaxy S6
