    Samsung Galaxy S6
    Cause 10 of 10: The phone lock code is activated
    The phone lock code is used to protect your mobile phone from unauthorised use. When the phone lock code is activated, it needs to be entered every time you turn on your mobile phone.
    Solution: Key in the phone lock code. You can now deactivate the phone lock code. If you've forgotten the phone lock code, contact the manufacturer for assistance.
    Step 1 of 24
    Step 2 of 24
    Step 3 of 24
    Press Screen lock type.
    Step 4 of 24
    You can create several types of phone lock codes. The steps below describe three examples:
    Create phone lock code using a pattern, go to 2a.
    Create phone lock code using your fingerprint, go to 2b.
    Create phone lock code using a PIN, go to 2c.
    Step 5 of 24
    Press Pattern.
    Step 6 of 24
    Press and drag a point to connect at least four points.
    Step 7 of 24
    Press CONTINUE.
    Repeat the selected phone lock code to confirm.
    Step 8 of 24
    Press CONFIRM.
    Step 9 of 24
    Key in a four-digit PIN and press CONTINUE.
    Step 10 of 24
    Key in the PIN again and press OK.
    Step 11 of 24
    Press the required setting.
    Step 12 of 24
    Press DONE.
    Step 13 of 24
    Press Fingerprint.
    Follow the instructions on the display to add a fingerprint.
    Step 14 of 24
    Key in a password and press CONTINUE.
    Step 15 of 24
    Key in the password again and press OK.
    Step 16 of 24
    Step 17 of 24
    Press DONE.
    Step 18 of 24
    Press PIN.
    Step 19 of 24
    Key in the required phone lock code and press CONTINUE.
    Step 20 of 24
    Key in the phone lock code again and press OK.
    Step 21 of 24
    Step 22 of 24
    Press DONE.
    Step 23 of 24
    Press None.
    Step 24 of 24
    1 Find " Screen lock type"
    2 Select option
    3 2a - Create phone lock code using a pattern
    Press Pattern.
    Press CONTINUE.
    Press CONFIRM.
    Press DONE.
    4 2b - Create phone lock code using your fingerprint
    Press Fingerprint.
    Press DONE.
    5 2c - Create phone lock code using a PIN
    Press PIN.
    Press DONE.
    6 Deactivate use of phone lock code
    Press None.
    7 Return to the Home screen
