    Samsung Galaxy S6
    Cause 6 of 10: Your mobile phone hasn't been assembled correctly
    If your mobile phone hasn't been assembled correctly, you can't turn on your mobile phone.
    Solution: Make sure your mobile phone has been assembled correctly.
    Step 1 of 4
    Insert the opener for the SIM card holder into the small hole in the SIM card holder on the side of your mobile phone.
    Step 2 of 4
    Remove the SIM card holder from your mobile phone.
    Step 3 of 4
    Turn your SIM card so that the angled corner of your SIM card matches the angled corner of the SIM card holder.
    Place your SIM card in the SIM card holder.
    Step 4 of 4
    Slide the SIM card holder into your mobile phone.
    1 Insert your SIM card
