    Samsung Galaxy S6
    I can't send and receive SMS
    Cause 2 of 3: The message centre number is incorrect
    The message centre ensures that your SMS is sent to the recipient. If the message centre number is incorrect, you can't send SMS.
    Solution: Enter the correct message centre number.
    Step 1 of 8
    Press Messages.
    Step 2 of 8
    Press MORE.
    Step 3 of 8
    Press Settings.
    Step 4 of 8
    Press More settings.
    Step 5 of 8
    Press Text messages.
    Step 6 of 8
    Press Message centre.
    Step 7 of 8
    Key in +41794999000 and press SET.
    Step 8 of 8
    1 Find "Text messages"
    Press Messages.
    Press MORE.
    Press Settings.
    2 Save the message centre number
    3 Return to the Home screen
