Login/account box
Mobile guides
Samsung Galaxy S6
I can't send and receive MMS
Cause 1 of 5: There's an error at the receiving end
If you have problems sending MMS to a specific recipient, the error might be at the receiving end.
Solution: Send an MMS to another recipient to check if the error is at the receiving end.
Step 1 of 15
Press Messages.
Step 2 of 15
Press the new message icon.
Step 3 of 15
Press the required contact.
Step 4 of 15
Press Enter message.
Write the text for your MMS.
Step 5 of 15
Press the attachment icon.
Insert a picture, go to 5a.
Insert a video clip, go to 5b.
Insert an audio file, go to 5c.
Step 6 of 15
Press Image.
Go to the required folder.
Step 7 of 15
Press the required picture to select it.
Step 8 of 15
Press DONE.
Step 9 of 15
Press Video.
Step 10 of 15
Press the required video clip.
Step 11 of 15
Press Audio.
Step 12 of 15
Press the required audio file.
Step 13 of 15
Press DONE.
Step 14 of 15
Press SEND when you've finished your MMS.
Step 15 of 15
1 Find "Messages"
Press Messages.
2 Write MMS
3 Select the recipient
4 Write the text
5 Insert pictures, video clips and audio files
6 5a - Insert a picture
Press Image.
Press DONE.
7 5b - Insert a video clip
Press Video.
8 5c - Insert an audio file
Press Audio.
Press DONE.
9 Send the MMS
10 Return to the Home screen
