    Samsung Galaxy S6
    I can't receive voice calls
    Cause 2 of 2: Divert of all calls is activated
    If divert of all calls is activated, you can't receive any calls. All incoming calls are diverted to your COMBOX® or another number.
    Solution: Deactivate divert of all calls.
    Step 1 of 13
    Press Phone.
    Step 2 of 13
    Press MORE.
    Step 3 of 13
    Press Settings.
    Step 4 of 13
    Press More settings.
    Step 5 of 13
    Press Call forwarding.
    Step 6 of 13
    Press Voice call.
    Step 7 of 13
    The current settings are displayed.
    Step 8 of 13
    Always forward
    Step 9 of 13
    Forward when busy
    Step 10 of 13
    Forward when unanswered
    Step 11 of 13
    Forward when unreachable
    Step 12 of 13
    Press DISABLE.
    Repeat until all diverts have been cancelled.
    Step 13 of 13
    1 Find "Voice call"
    Press Phone.
    Press MORE.
    Press Settings.
    Press Voice call.
    2 Cancel all diverts
    Always forward
    Forward when busy
    Press DISABLE.
    3 Return to the Home screen
