Login/account box
Mobile guides
Samsung Galaxy S6
I can't make voice calls
Cause 5 of 9: Your mobile phone is set to connect to 3G networks only
If your mobile phone is set to connect to 3G networks only, it can't find a network if you're in an area with poor or no 3G network coverage.
Solution: Change network mode allowing your mobile phone to connect to both 2G and 3G networks.
Step 1 of 5
Step 2 of 5
Press Mobile networks.
Step 3 of 5
Press Network mode.
Step 4 of 5
Press 4G/3G/2G (auto connect), 3G/2G (auto connect), 3G only or 2G only.
Step 5 of 5
1 Find " Network mode"
Press Network mode.
2 Select network mode
3 Return to the Home screen
