    Samsung Galaxy S6
    Back to Getting started
    Guide to phone keys and sockets
    Follow these instructions for a guide on how to use the phone keys and sockets.
    Step 1 of 21
    Several functions are associated with On/Off:
    Step 2 of 21
    Press On/Off to turn your mobile phone on or off.
    Step 3 of 21
    Press On/Off to activate the screen lock.
    Step 4 of 21
    Press and hold On/Off to access the functions silent mode and flight mode.
    Step 5 of 21
    Press the Return key to exit an active menu item or hide the keypad.
    Step 6 of 21
    Several functions are associated with the Application key:
    Step 7 of 21
    Press the Application key to view a list of the most recently used menu items and applications.
    Step 8 of 21
    Press and hold the Application key to use two applications at the same time.
    Step 9 of 21
    Several functions are associated with the Home key:
    Step 10 of 21
    Press the Home key to return to the Home screen.
    Step 11 of 21
    Press and hold the Home key to search the Internet.
    Step 12 of 21
    Press the Home key twice in quick succession to activate the camera.
    Step 13 of 21
    Several functions are associated with the Volume keys:
    Step 14 of 21
    Press the Top volume key or the Bottom volume key to adjust the volume.
    Step 15 of 21
    Press the Top volume key or the Bottom volume key during a call to adjust the volume.
    Step 16 of 21
    Press the Top volume key or the Bottom volume key to silence the incoming call alert.
    Step 17 of 21
    Connect the charger or data cable to the socket and to a wall socket or your computer's USB port.
    Step 18 of 21
    Connect the headset to the headset socket.
    Step 19 of 21
    Place the tip of your finger on the heart rate sensor to check your heart rate when using S Health.
    Step 20 of 21
    Point the camera lens at the back of your mobile phone at the required object to take a picture or record a video clip.
    Step 21 of 21
    Point the camera lens at the front of your mobile phone at the required object during a video call.
    1. On/Off
    2. The Return key
    3. The Application key
    4. The Home key
    5. The Volume keys
    6. Socket
    7. Headset socket
    8. Heart rate sensor
    9. Camera lens at the back of your mobile phone
    10. Camera lens at the front of your mobile phone
