    Samsung Galaxy S6
    Back to Calls & contacts
    How to call COMBOX®
    You can listen to the messages left on your COMBOX®. Remember, you need to save your COMBOX® number and divert calls to COMBOX®.
    Step 1 of 6
    Press Phone.
    Step 2 of 6
    Press the keypad icon.
    Step 3 of 6
    Press and hold 1 to call COMBOX®.
    Step 4 of 6
    Follow the instructions from COMBOX®.
    Step 5 of 6
    Press the end call icon to end the call.
    Step 6 of 6
    1. Call COMBOX®
    Press Phone.
    2. Check voice messages
    3. Return to the Home screen
