    Samsung Galaxy S6 edge +
    How to activate or deactivate silent mode
    When you activate silent mode, all phone sounds are deactivated.
    Step 1 of 1
    Press the sound setting icon the necessary number times to activate or deactivate silent mode.
    1. Activate or deactivate silent mode
