Login/account box
Mobile guides
Samsung Galaxy S6 edge +
I can't use WLAN
Cause 5 of 6: WLAN isn't activated on your mobile phone
If WLAN is deactivated on your mobile phone, you can't access the Internet using a WLAN.
Solution: Activate WLAN.
Step 1 of 6
Step 2 of 6
Press Wi-Fi.
Step 3 of 6
Press the indicator next to "Wi-Fi" until the function is activated.
Step 4 of 6
Press the required WLAN.
Step 5 of 6
Press CONNECT.
Step 6 of 6
1 Find " Wi-Fi"
Press Wi-Fi.
2 Activate WLAN
3 Connect to WLAN
Press CONNECT.
4 Return to the Home screen
