    Samsung Galaxy S6 edge +
    I can't use WLAN
    Cause 2 of 6: You're connected to a WLAN but you're not logged on
    Some WLANs require that you log on.
    Solution: Open the browser on your mobile phone and try to load a website. The browser is directed to the start page of the WLAN. Follow the instructions to log on. If you can't log on to the WLAN, deactivate WLAN on your mobile phone and connect to the Internet using the mobile network.
    Step 1 of 8
    Press Internet.
    Step 2 of 8
    Press the address bar.
    Step 3 of 8
    Key in the address of the required website and press Go.
    Step 4 of 8
    Press MORE.
    Step 5 of 8
    Press Add to Bookmarks.
    Step 6 of 8
    Press Bookmarks.
    Step 7 of 8
    Press the required bookmark.
    Step 8 of 8
    1 Find "Internet"
    Press Internet.
    2 Enter a web address
    3 Add the current website to your bookmarks
    Press MORE.
    4 Go to a bookmark
    Press Bookmarks.
    5 Return to the Home screen
