    Samsung Galaxy S6 edge +
    Cause 9 of 10: Your mobile phone isn't turned on correctly
    Your mobile phone won't turn on if it's not done correctly.
    Solution: Turn on your mobile phone correctly.
    Step 1 of 5
    Press On/Off until your mobile phone is turned on.
    Step 2 of 5
    Key in your PIN and press OK.
    If your mobile phone rejects your SIM:
    Contact your distributor or service provider where you bought your mobile phone.
    Step 3 of 5
    Press and hold On/Off.
    Step 4 of 5
    Press Power off.
    Step 5 of 5
    Press POWER OFF.
    1 Turn on your mobile phone
    2 Enter PIN
    3 Turn off your mobile phone
    Press Power off.
    Press POWER OFF.
