    Samsung Galaxy S6 edge +
    I can't install apps
    Cause 1 of 3: The required app isn't available in your country
    If the app isn't available in your country, you can't install it.
    Solution: Search for similar apps or wait for the app to become available in your country.
    Step 1 of 13
    Press Apps.
    Step 2 of 13
    Press Play Store.
    Step 3 of 13
    To search by category:
    Press APPS or GAMES.
    Step 4 of 13
    Press CATEGORIES.
    Go to the required category.
    Step 5 of 13
    To search by name:
    Press Google play.
    Step 6 of 13
    Key in the name of the required app and press the search icon.
    Step 7 of 13
    Press the required app.
    Step 8 of 13
    To install a free app:
    Press INSTALL.
    Step 9 of 13
    Press ACCEPT.
    Step 10 of 13
    To buy an app:
    Press the price.
    Step 11 of 13
    Follow the instructions on the display to install the app.
    Press the Home key to return to the Home screen.
    Step 12 of 13
    Press Apps.
    Step 13 of 13
    Press the app you've just installed.
    Follow the instructions on the display to use the app.
    1 Find "Play Store"
    Press Apps.
    Press Play Store.
    2 Find an app
    Press CATEGORIES.
    To search by name:
    Press Google play.
    3 Install the app
    Press INSTALL.
    Press ACCEPT.
    To buy an app:
    Press the price.
    4 Use the app
    Press Apps.
