    Samsung Galaxy S6 edge +
    I can't send and receive SMS
    Cause 1 of 3: There's an error at the receiving end
    If you're having problems sending SMS to a specific number, the error might be at the receiving end.
    Solution: Send an SMS to another number to check if the error is at the receiving end.
    Step 1 of 6
    Press Messages.
    Step 2 of 6
    Press the new message icon.
    Step 3 of 6
    Press the required contact.
    Step 4 of 6
    Press Enter message.
    Write the text for your SMS.
    Step 5 of 6
    Press SEND when you've written your SMS.
    Step 6 of 6
    1 Find "Messages"
    Press Messages.
    2 Write SMS
    3 Enter the recipient
    4 Write the text
    5 Send the SMS
    6 Return to the Home screen
