Login/account box
Mobile guides
Samsung Galaxy S6 edge +
I can't send and receive MMS
Cause 4 of 5: Mobile data is deactivated on your mobile phone
If mobile data is deactivated on your mobile phone, you can't send and receive MMS.
Solution: Activate mobile data.
Step 1 of 2
Press the mobile data icon to activate or deactivate the function.
Step 2 of 2
1 Activate or deactivate mobile data
2 Return to the Home screen
