    Samsung Galaxy S6 edge +
    I can't send and receive MMS
    Cause 3 of 5: The MMS is written incorrectly
    The MMS can't be sent if it's written incorrectly.
    Solution: Write an MMS correctly.
    Step 1 of 15
    Press Messages.
    Step 2 of 15
    Press the new message icon.
    Step 3 of 15
    Press the required contact.
    Step 4 of 15
    Press Enter message.
    Write the text for your MMS.
    Step 5 of 15
    Press the attachment icon.
    Insert a picture, go to 5a.
    Insert a video clip, go to 5b.
    Insert an audio file, go to 5c.
    Step 6 of 15
    Press Image.
    Go to the required folder.
    Step 7 of 15
    Press the required picture to select it.
    Step 8 of 15
    Press DONE.
    Step 9 of 15
    Press Video.
    Step 10 of 15
    Press the required video clip.
    Step 11 of 15
    Press Audio.
    Step 12 of 15
    Press the required audio file.
    Step 13 of 15
    Press DONE.
    Step 14 of 15
    Press SEND when you've finished your MMS.
    Step 15 of 15
    1 Find "Messages"
    Press Messages.
    2 Write MMS
    3 Select the recipient
    4 Write the text
    5 Insert pictures, video clips and audio files
    6 5a - Insert a picture
    Press Image.
    Press DONE.
    7 5b - Insert a video clip
    Press Video.
    8 5c - Insert an audio file
    Press Audio.
    Press DONE.
    9 Send the MMS
    10 Return to the Home screen
