    Samsung Galaxy S6 edge +
    I can't send and receive e-mails
    Cause 3 of 3: Your mobile phone hasn't been correctly set up for e-mail
    If your mobile phone hasn't been correctly set up for e-mail, you can't send and receive e-mail.
    Solution: set up your mobile phone for Exchange e-mail.
    Step 1 of 21
    Press Apps.
    Step 2 of 21
    Press Email.
    Step 3 of 21
    Key in your e-mail address.
    Step 4 of 21
    Press Password and key in the password for your e-mail account.
    Step 5 of 21
    Press NEXT.
    Step 6 of 21
    Press MORE.
    Step 7 of 21
    Press Settings.
    Step 8 of 21
    Press the name of the e-mail account you've just set up.
    Step 9 of 21
    Press Account name.
    Step 10 of 21
    Key in the required name and press OK.
    Step 11 of 21
    Press Your name.
    Step 12 of 21
    Key in the required sender name and press OK.
    Step 13 of 21
    Press Sync schedule.
    Step 14 of 21
    Press Set sync schedule.
    Step 15 of 21
    Press Auto (when received), Manual or the required period.
    Step 16 of 21
    Press the Return key the necessary number of times.
    Step 17 of 21
    Press Notifications.
    Step 18 of 21
    Press the name of your e-mail account.
    Step 19 of 21
    Press the indicator below the name of your e-mail account to activate or deactivate the function.
    Step 20 of 21
    Step 21 of 21
    1 Find "Email"
    Press Apps.
    Press Email.
    2 Enter the e-mail address
    3 Enter password
    Press NEXT.
    4 Enter e-mail account name
    Press MORE.
    Press Settings.
    Press Account name.
    5 Enter sender name
    Press Your name.
    6 Select settings for retrieval of new e-mails
    7 Activate or deactivate e-mail notification
    8 Finish setup
    9 Return to the Home screen
