    Samsung Galaxy S6 edge +
    I can't send and receive e-mails
    Cause 1 of 3: The incoming or outgoing server isn't accessible from the mobile network or the WLAN you're connected to
    The incoming and outgoing server you're using need to be accessible from a mobile network or the WLAN you're connected to.
    Solution: Contact your e-mail provider for more information.
