    Samsung Galaxy S6 edge +
    I can't receive voice calls
    Cause 1 of 2: Your mobile phone isn't responding
    Your mobile phone may not respond due to overload or errors in the operating system.
    Solution: Restart your mobile phone.
    Step 1 of 1
    Turn off your mobile phone.
    Wait for 10-15 seconds.
    Turn on your mobile phone again.
    1 Restart your mobile phone
