Login/account box
Mobile guides
Samsung Galaxy S6 edge +
I can't make voice calls
Cause 3 of 9: There's an error at the receiving end
If you're having problems calling a specific number, the error might be at the receiving end.
Solution: Try calling another number. If you can call another number, the error is probably at the receiving end.
