    Samsung Galaxy S6 edge +
    I can't make voice calls
    Cause 1 of 9: Fixed dialling is activated
    Fixed dialling allows you to select which numbers can be called from your mobile phone and to which numbers you can send messages. When fixed dialling is activated, you can only call and send messages to numbers on the list of fixed dialling numbers.
    Solution: Deactivate fixed dialling.
    Step 1 of 9
    Press Phone.
    Step 2 of 9
    Press MORE.
    Step 3 of 9
    Press Settings.
    Step 4 of 9
    Press More settings.
    Step 5 of 9
    Press Fixed Dialling Numbers.
    Step 6 of 9
    To activate fixed dialling:
    Press Enable FDN.
    Step 7 of 9
    To deactivate fixed dialling:
    Press Disable FDN.
    Step 8 of 9
    Key in your PIN2 and press OK.
    Step 9 of 9
    1 Find "Fixed Dialling Numbers"
    Press Phone.
    Press MORE.
    Press Settings.
    2 Activate or deactivate fixed dialling
    Press Enable FDN.
    Press Disable FDN.
    3 Return to the Home screen
