    Samsung Galaxy S6 edge +
    I can't check my COMBOX®
    Cause 3 of 3: COMBOX® hasn't been set up
    If you haven't selected COMBOX® settings, you can't check your COMBOX® messages.
    Solution: Follow the instructions to set up your COMBOX®.
