    Samsung Galaxy S6 edge +
    I can't check my COMBOX®
    Cause 1 of 3: You're abroad or using another mobile phone
    If you're calling to check your COMBOX® when abroad or from another mobile phone, you need to call a different number.
    Solution: Call +41794997979 and follow the instructions.
