    Samsung Galaxy S6 edge +
    Back to Messaging & Internet
    How to write and send e-mails
    You can send and receive e-mails from your e-mail accounts. Remember, you need to set up your mobile phone for e-mail.
    Step 1 of 14
    Press Apps.
    Step 2 of 14
    Press Email.
    Step 3 of 14
    Press the drop down list in the top left corner of the display.
    Step 4 of 14
    Press the required e-mail account.
    Step 5 of 14
    Press the new e-mail icon.
    Step 6 of 14
    Press the required contact.
    Repeat the procedure to add more recipients.
    Step 7 of 14
    Press Subject and key in a subject for the e-mail.
    Step 8 of 14
    Press the text input field.
    Write the text for your e-mail.
    Step 9 of 14
    Press ATTACH.
    Step 10 of 14
    Press My Files.
    Go to the required folder.
    Step 11 of 14
    Press the required file.
    Step 12 of 14
    Press DONE.
    Step 13 of 14
    Press SEND when you've finished your e-mail.
    Step 14 of 14
    1. Find "Email"
    Press Apps.
    Press Email.
    2. Select e-mail account
    3. Write the e-mail
    4. Select the recipient
    5. Enter subject
    6. Write the text
    7. Attach file
    Press ATTACH.
    Press My Files.
    Press DONE.
    8. Send the e-mail
    9. Return to the Home screen
