    Samsung Galaxy S6 edge +
    Back to Getting started
    How to set up your mobile phone for MMS
    An MMS is a message which can contain pictures and other media files and can be sent to other mobile phones and e-mail addresses. You'll be able to send and receive MMS as soon as you've inserted your SIM into your mobile phone. If this isn't the case, we can send an MMS configuration to your mobile phone or you can set up your mobile phone manually.
    Step 1 of 27
    Step 2 of 27
    Press Mobile networks.
    Step 3 of 27
    Press Access Point Names.
    Step 4 of 27
    Press ADD.
    Step 5 of 27
    Press Name.
    Step 6 of 27
    Key in Swisscom MMS and press OK.
    Step 7 of 27
    Press APN.
    Step 8 of 27
    Key in event.swisscom.ch and press OK.
    Step 9 of 27
    Press MMSC.
    Step 10 of 27
    Key in http://mms.natel.ch:8079 and press OK.
    Step 11 of 27
    Press MMS proxy.
    Step 12 of 27
    Key in 192.168.210.2 and press OK.
    Step 13 of 27
    Press MMS port.
    Step 14 of 27
    Key in 8080 and press OK.
    Step 15 of 27
    Press MCC.
    Step 16 of 27
    Key in 228 and press OK.
    Step 17 of 27
    Press MNC.
    Step 18 of 27
    Key in 01 and press OK.
    Step 19 of 27
    Press Authentication type.
    Step 20 of 27
    Press None.
    Step 21 of 27
    Press APN type.
    Step 22 of 27
    Key in mms and press OK.
    Step 23 of 27
    Press Bearer.
    Step 24 of 27
    Press Unspecified.
    Step 25 of 27
    Press MORE.
    Step 26 of 27
    Press Save.
    Step 27 of 27
    1. Find " Access Point Names"
    2. Set up a new data connection
    Press ADD.
    3. Enter a data connection name
    Press Name.
    4. Enter APN
    Press APN.
    5. Enter the MMS server
    Press MMSC.
    6. Enter the IP address
    Press MMS proxy.
    7. Enter the port number
    Press MMS port.
    8. Enter the country code
    Press MCC.
    9. Enter the network code
    Press MNC.
    10. Select the authentication type
    Press None.
    11. Select the APN type
    Press APN type.
    12. Select data bearer
    Press Bearer.
    Press Unspecified.
    13. Save the data connection
    Press MORE.
    Press Save.
    14. Return to the Home screen
