    Samsung Galaxy S6 edge +
    Back to Calls & contacts
    How to cancel all diverts
    If you no longer wish to divert your calls, you need to cancel the diverts.
    Step 1 of 13
    Press Phone.
    Step 2 of 13
    Press MORE.
    Step 3 of 13
    Press Settings.
    Step 4 of 13
    Press More settings.
    Step 5 of 13
    Press Call forwarding.
    Step 6 of 13
    Press Voice call.
    Step 7 of 13
    The current settings are displayed.
    Step 8 of 13
    Always forward
    Step 9 of 13
    Forward when busy
    Step 10 of 13
    Forward when unanswered
    Step 11 of 13
    Forward when unreachable
    Step 12 of 13
    Press DISABLE.
    Repeat until all diverts have been cancelled.
    Step 13 of 13
    1. Find "Voice call"
    Press Phone.
    Press MORE.
    Press Settings.
    Press Voice call.
    2. Cancel all diverts
    Always forward
    Forward when busy
    Press DISABLE.
    3. Return to the Home screen
