    Samsung Galaxy S6 edge +
    Back to Calls & contacts
    How to activate or deactivate your own caller identification
    You can deactivate your own caller identification, your number will then not be displayed at the receiving end when you make a call. You can also make one call with hidden caller identification. Your number is only hidden when you make voice calls not when you send messages.
    Step 1 of 7
    Press Phone.
    Step 2 of 7
    Press MORE.
    Step 3 of 7
    Press Settings.
    Step 4 of 7
    Press More settings.
    Step 5 of 7
    Press Show my caller ID.
    Step 6 of 7
    Press Hide number or Show number.
    Step 7 of 7
    1. Find "Show my caller ID"
    Press Phone.
    Press MORE.
    Press Settings.
    2. Activate or deactivate your own caller identification
    3. Return to the Home screen
