    Samsung Galaxy S6 edge +
    Back to Calls & contacts
    How to activate or deactivate call waiting
    When call waiting is activated, you can answer a new call without ending your ongoing call.
    Step 1 of 6
    Press Phone.
    Step 2 of 6
    Press MORE.
    Step 3 of 6
    Press Settings.
    Step 4 of 6
    Press More settings.
    Step 5 of 6
    The current settings are displayed.
    Press Call waiting to activate or deactivate the function.
    Step 6 of 6
    1. Find "More settings"
    Press Phone.
    Press MORE.
    Press Settings.
    2. Activate or deactivate call waiting
    3. Return to the Home screen
