    Samsung Galaxy S6 edge +
    Back to Calls & contacts
    Activate or deactivate fixed dialling
    When fixed dialling is turned on, you can only call selected numbers and do emergency calls. Incoming calls aren't affected.
    Step 1 of 9
    Press Phone.
    Step 2 of 9
    Press MORE.
    Step 3 of 9
    Press Settings.
    Step 4 of 9
    Press More settings.
    Step 5 of 9
    Press Fixed Dialling Numbers.
    Step 6 of 9
    To activate fixed dialling:
    Press Enable FDN.
    Step 7 of 9
    To deactivate fixed dialling:
    Press Disable FDN.
    Step 8 of 9
    Key in your PIN2 and press OK.
    Step 9 of 9
    1. Find "Fixed Dialling Numbers"
    Press Phone.
    Press MORE.
    Press Settings.
    2. Activate or deactivate fixed dialling
    Press Enable FDN.
    Press Disable FDN.
    3. Return to the Home screen
