    Samsung Galaxy S5
    How to activate or deactivate use of phone lock code
    Step 1 of 18
    Step 2 of 18
    Press Lock screen.
    Step 3 of 18
    Press Screen lock.
    Step 4 of 18
    You can create several types of phone lock codes. The steps below describe three examples:
    Create phone lock code using a pattern, go to 2a.
    Create phone lock code using your fingerprint, go to 2b.
    Create phone lock code using a PIN, go to 2c.
    Step 5 of 18
    Press Pattern.
    Step 6 of 18
    Press and drag a point to connect at least four points.
    Step 7 of 18
    Press Continue.
    Repeat the selected phone lock code to confirm.
    Step 8 of 18
    Press Confirm.
    Step 9 of 18
    Key in a four-digit PIN and press Continue.
    Step 10 of 18
    Key in the PIN again and press OK.
    Step 11 of 18
    Press Fingerprint.
    Follow the instructions on the display to add a fingerprint.
    Step 12 of 18
    Key in a password and press Continue.
    Step 13 of 18
    Key in the password again and press OK.
    Step 14 of 18
    Press PIN.
    Step 15 of 18
    Key in the required phone lock code and press Continue.
    Step 16 of 18
    Key in the phone lock code again and press OK.
    Step 17 of 18
    Press None.
    Step 18 of 18
    1. Find " Screen lock"
    Press Lock screen.
    Press Screen lock.
    2. Select option
    3. 2a - Create phone lock code using a pattern
    Press Pattern.
    Press Continue.
    Press Confirm.
    4. 2b - Create phone lock code using your fingerprint
    Press Fingerprint.
    5. 2c - Create phone lock code using a PIN
    Press PIN.
    6. Deactivate use of phone lock code
    Press None.
    7. Return to the Home screen
