    Samsung Galaxy S5
    I can't use tethering on my mobile phone
    Cause 1 of 1: Your computer and mobile phone haven't been correctly set up for tethering
    You need to set up your computer and mobile phone correctly before you can use tethering.
    Solution: Set up your mobile phone and computer for tethering.
    Step 1 of 6
    Open the cover at the bottom of your mobile phone.
    Step 2 of 6
    Step 3 of 6
    Step 4 of 6
    Press Tethering and Wi-Fi hotspot.
    Step 5 of 6
    Press USB tethering until the function is activated.
    Step 6 of 6
    An Internet connection from your computer via your mobile phone is automatically established.
    When the connection is established, you can access the Internet from your computer.
    1 Connect your mobile phone and computer
    2 Activate tethering
    3 Establish connection
