    Samsung Galaxy S5
    I can't use my mobile phone as a Wi-Fi hotspot
    Cause 1 of 2: An incorrect password has been entered on the connected device
    The password used on your mobile phone needs to entered on the device you want to connect from.
    Solution: Key in the correct password.
    Step 1 of 15
    Step 2 of 15
    Press Tethering and Wi-Fi hotspot.
    Step 3 of 15
    Press Mobile hotspot.
    Step 4 of 15
    Press the menu icon.
    Step 5 of 15
    Press Configure.
    Step 6 of 15
    Press the field below "Network SSID" and key in the required name for the Wi-Fi hotspot.
    Step 7 of 15
    Press the drop down list below "Security".
    Step 8 of 15
    If you don't want to password protect your hotspot:
    Press Open.
    Step 9 of 15
    Press WPA2 PSK.
    Step 10 of 15
    Step 11 of 15
    Press Save.
    Step 12 of 15
    Press the indicator next to "Mobile hotspot" until the function is activated.
    Step 13 of 15
    If WLAN is activated:
    Press OK to confirm.
    Step 14 of 15
    Activate WLAN.
    Step 15 of 15
    1 Find " Configure"
    Press Configure.
    2 Select settings for Wi-Fi hotspot
    Press Open.
    Press WPA2 PSK.
    Press Save.
    3 Activate Wi-Fi hotspot
    4 Establish a connection
    Activate WLAN.
    5 Return to the Home screen
