Login/account box
Mobile guides
Samsung Galaxy S5
Cause 10 of 10: The phone lock code is activated
The phone lock code is used to protect your mobile phone from unauthorised use. When the phone lock code is activated, it needs to be entered every time you turn on your mobile phone.
Solution: Key in the phone lock code. You can now deactivate the phone lock code. If you've forgotten the phone lock code, contact the manufacturer for assistance.
Step 1 of 18
Step 2 of 18
Press Lock screen.
Step 3 of 18
Press Screen lock.
Samsung Galaxy S5
Step 4 of 18
You can create several types of phone lock codes. The steps below describe three examples:
Create phone lock code using a pattern, go to 2a.
Create phone lock code using your fingerprint, go to 2b.
Create phone lock code using a PIN, go to 2c.
Step 5 of 18
Press Pattern.
Step 6 of 18
Press and drag a point to connect at least four points.
Step 7 of 18
Press Continue.
Repeat the selected phone lock code to confirm.
Step 8 of 18
Press Confirm.
Step 9 of 18
Key in a four-digit PIN and press Continue.
Step 10 of 18
Key in the PIN again and press OK.
Step 11 of 18
Press Fingerprint.
Follow the instructions on the display to add a fingerprint.
Step 12 of 18
Key in a password and press Continue.
Step 13 of 18
Key in the password again and press OK.
Step 14 of 18
Press PIN.
Step 15 of 18
Key in the required phone lock code and press Continue.
Step 16 of 18
Key in the phone lock code again and press OK.
Step 17 of 18
Press None.
Step 18 of 18
1 Find " Screen lock"
Press Lock screen.
Press Screen lock.
2 Select option
Samsung Galaxy S5
3 2a - Create phone lock code using a pattern
Press Pattern.
Press Continue.
Press Confirm.
4 2b - Create phone lock code using your fingerprint
Press Fingerprint.
5 2c - Create phone lock code using a PIN
Press PIN.
6 Deactivate use of phone lock code
Press None.
7 Return to the Home screen
