    Samsung Galaxy S5
    Cause 6 of 10: Your mobile phone hasn't been assembled correctly
    If your mobile phone hasn't been assembled correctly, you can't turn on your mobile phone.
    Solution: Make sure your mobile phone has been assembled correctly.
    Step 1 of 5
    Turn the back of your mobile phone towards you.
    Take hold of the left side of the back cover and remove it.
    Step 2 of 5
    Place your SIM card as illustrated next to the SIM card holder.
    Step 3 of 5
    Slide your SIM card into the holder.
    Step 4 of 5
    Place the battery in your mobile phone (top first), matching the battery contacts with the phone contacts, and press the battery into place.
    Step 5 of 5
    Place the back cover on your mobile phone and press it into place.
    1 Remove the back cover
    2 Insert your SIM card
    3 Insert the battery
    4 Replace the back cover
