    Samsung Galaxy S5
    Cause 1 of 10: The battery is flat
    If the battery is flat, you can't turn on your mobile phone.
    Solution: Charge the battery.
    Step 1 of 4
    Open the cover at the bottom of your mobile phone.
    Step 2 of 4
    Connect the charging cable to the socket and to wall socket.
    Step 3 of 4
    When the battery charging icon is displayed, charging is in progress.
    Step 4 of 4
    When the battery is fully charged, you can remove the charger from the wall socket and your mobile phone.
    1 Connect the charger to your mobile phone
    2 End charging
