    Samsung Galaxy S5
    I can't send and receive MMS
    Cause 5 of 5: Your mobile phone hasn't been correctly set up for MMS
    If your mobile phone hasn't been correctly set up for MMS, you can't send and receive MMS.
    Solution: Set up your mobile phone for MMS.
    Step 1 of 28
    Step 2 of 28
    Press More networks.
    Step 3 of 28
    Press Mobile networks.
    Step 4 of 28
    Press Access Point Names.
    Step 5 of 28
    Press the new data connection icon.
    Step 6 of 28
    Press Name.
    Step 7 of 28
    Key in Swisscom MMS and press OK.
    Step 8 of 28
    Press APN.
    Step 9 of 28
    Key in event.swisscom.ch and press OK.
    Step 10 of 28
    Press MMSC.
    Step 11 of 28
    Key in http://mms.natel.ch:8079 and press OK.
    Step 12 of 28
    Press MMS proxy.
    Step 13 of 28
    Key in 192.168.210.2 and press OK.
    Step 14 of 28
    Press MMS port.
    Step 15 of 28
    Key in 8080 and press OK.
    Step 16 of 28
    Press MCC.
    Step 17 of 28
    Key in 228 and press OK.
    Step 18 of 28
    Press MNC.
    Step 19 of 28
    Key in 01 and press OK.
    Step 20 of 28
    Press Authentication type.
    Step 21 of 28
    Press None.
    Step 22 of 28
    Press APN type.
    Step 23 of 28
    Key in mms and press OK.
    Step 24 of 28
    Press Bearer.
    Step 25 of 28
    Press Unspecified.
    Step 26 of 28
    Press the menu icon.
    Step 27 of 28
    Press Save.
    Step 28 of 28
    1 Find " Access Point Names"
    2 Set up a new data connection
    3 Enter a data connection name
    Press Name.
    4 Enter APN
    Press APN.
    5 Enter the MMS server
    Press MMSC.
    6 Enter the IP address
    Press MMS proxy.
    7 Enter the port number
    Press MMS port.
    8 Enter the country code
    Press MCC.
    9 Enter the network code
    Press MNC.
    10 Select the authentication type
    Press None.
    11 Select the APN type
    Press APN type.
    12 Select data bearer
    Press Bearer.
    Press Unspecified.
    13 Save the data connection
    Press Save.
    14 Return to the Home screen
