    Samsung Galaxy S5
    I can't send and receive MMS
    Cause 2 of 5: You're abroad and data roaming is deactivated on your mobile phone
    If you're abroad and data roaming is deactivated on your mobile phone, you can't send and receive MMS.
    Solution: Activate data roaming.
    Step 1 of 6
    Step 2 of 6
    Press More networks.
    Step 3 of 6
    Press Mobile networks.
    Step 4 of 6
    Step 5 of 6
    If you activate data roaming:
    Press OK to confirm.
    Step 6 of 6
    1 Find " Mobile networks"
    2 Activate or deactivate data roaming
    3 Return to the Home screen
