    Samsung Galaxy S5
    I can't send and receive e-mails
    Cause 2 of 3: The e-mail is written incorrectly
    The e-mail can't be sent if it's written incorrectly.
    Solution: Write an e-mail correctly.
    Step 1 of 14
    Press Apps.
    Step 2 of 14
    Press Email.
    Step 3 of 14
    Press the menu icon in the top left corner of the display.
    Step 4 of 14
    Press Inbox below the required e-mail account.
    Step 5 of 14
    Press the new e-mail icon.
    Step 6 of 14
    Press the required contact.
    Repeat the procedure to add more recipients.
    Step 7 of 14
    Press Subject and key in a subject for the e-mail.
    Step 8 of 14
    Press the text input field.
    Write the text for your e-mail.
    Step 9 of 14
    Press the attachment icon.
    Step 10 of 14
    Press My Files.
    Go to the required folder.
    Step 11 of 14
    Press the box next to the required file to select the file.
    Step 12 of 14
    Press Done.
    Step 13 of 14
    Press the send icon when you've finished your e-mail.
    Step 14 of 14
    1 Find "Email"
    Press Apps.
    Press Email.
    2 Select e-mail account
    3 Write the e-mail
    4 Select the recipient
    5 Enter subject
    6 Write the text
    7 Attach file
    Press My Files.
    Press Done.
    8 Send the e-mail
    9 Return to the Home screen
