    Samsung Galaxy S5
    I can't receive voice calls
    Cause 2 of 2: Divert of all calls is activated
    If divert of all calls is activated, you can't receive any calls. All incoming calls are diverted to your COMBOX® or another number.
    Solution: Deactivate divert of all calls.
    Step 1 of 15
    Press Phone.
    Step 2 of 15
    Press Keypad.
    Step 3 of 15
    Press the menu icon.
    Step 4 of 15
    Press Settings.
    Step 5 of 15
    Press Call.
    Step 6 of 15
    Press More settings.
    Step 7 of 15
    Press Call forwarding.
    Step 8 of 15
    Press Voice call.
    Step 9 of 15
    The current settings are displayed.
    Step 10 of 15
    Always forward
    Step 11 of 15
    Forward when busy
    Step 12 of 15
    Forward when unanswered
    Step 13 of 15
    Forward when unreachable
    Step 14 of 15
    Press Disable.
    Repeat until all diverts have been cancelled.
    Step 15 of 15
    1 Find "Voice call"
    Press Phone.
    Press Keypad.
    Press Settings.
    Press Call.
    Press Voice call.
    2 Cancel all diverts
    Always forward
    Forward when busy
    Press Disable.
    3 Return to the Home screen
