    Samsung Galaxy S5
    I can't receive messages on my COMBOX®
    Cause 1 of 1: Voice calls aren't diverted to your COMBOX®
    Missed calls are only diverted to your COMBOX® if the correct settings have been selected. You can change the settings in the phone menu.
    Solution: Divert calls to your COMBOX®.
    Step 1 of 15
    Press Phone.
    Step 2 of 15
    Press Keypad.
    Step 3 of 15
    Press the menu icon.
    Step 4 of 15
    Press Settings.
    Step 5 of 15
    Press Call.
    Step 6 of 15
    Press More settings.
    Step 7 of 15
    Press Call forwarding.
    Step 8 of 15
    Press Voice call.
    Step 9 of 15
    The current settings are displayed.
    Step 10 of 15
    Always forward
    Step 11 of 15
    Forward when busy
    Step 12 of 15
    Forward when unanswered
    Step 13 of 15
    Forward when unreachable
    Step 14 of 15
    Key in +4186(area code)(your phone number) and press Enable.
    Step 15 of 15
    1 Find "Voice call"
    Press Phone.
    Press Keypad.
    Press Settings.
    Press Call.
    Press Voice call.
    2 Select divert type
    Always forward
    Forward when busy
    3 Divert calls to COMBOX®
    4 Return to the Home screen
