    Samsung Galaxy S5
    I can't make voice calls
    Cause 7 of 9: You've activated manual network selection and are out of range of the selected network
    If you've activated manual network selection and are out of range of the selected network, you can't make calls.
    Solution: Activate automatic network selection.
    Step 1 of 8
    Step 2 of 8
    Press More networks.
    Step 3 of 8
    Press Mobile networks.
    Step 4 of 8
    Press Network operators.
    Step 5 of 8
    Select a network manually, go to 2a.
    Select a network automatically, go to 2b.
    Step 6 of 8
    Press the required network.
    Step 7 of 8
    Press Select automatically.
    Step 8 of 8
    1 Find " Network operators"
    2 Select an option
    3 2a - Select a network manually
    4 2b - Select a network automatically
    5 Return to the Home screen
