Login/account box
Mobile guides
Samsung Galaxy S
Back to Select settings
How to select a ring tone
Step 1 of 9
Press Applications.
Step 2 of 9
Press Settings.
Step 3 of 9
Press Sound.
Step 4 of 9
Press Silent mode to deactivate silent mode.
Step 5 of 9
When the box next to the menu item is empty, silent mode is deactivated.
Step 6 of 9
Press Phone ringtone.
Step 7 of 9
Step 8 of 9
Once you've found a ring tone you like, press OK.
Step 9 of 9
1. Find "Sound"
Press Applications.
Press Settings.
Press Sound.
2. Deactivate silent mode
3. Select ring tone
4. Return to the Home screen
