Login/account box
Samsung Galaxy S
How to connect to a WLAN
You can use WLAN as an alternative to the mobile network to connect to the Internet. Your mobile phone doesn't use data traffic when connected to a WLAN.
Step 1 of 9
Press Applications.
Step 2 of 9
Press Settings.
Step 3 of 9
Press Wireless and network.
Step 4 of 9
Press Wi-Fi settings.
Step 5 of 9
Press Wi-Fi to activate WLAN.
Step 6 of 9
When the box next to the menu item is ticked (V), WLAN is activated.
Step 7 of 9
Press the required network.
Step 8 of 9
Follow the instructions on the display to key in security settings.
Press Connect.
Step 9 of 9
1. Find "Wi-Fi settings"
Press Applications.
Press Settings.
2. Activate WLAN
3. Connect to a WLAN
Press Connect.
4. Return to the Home screen
Customer Center
