Login/account box
Samsung Galaxy S
How to connect a Bluetooth device to your mobile phone
Bluetooth is a wireless connection which can be used to transfer files between two devices or to establish a connection to other devices, such as a wireless headset.
Step 1 of 9
Press Applications.
Step 2 of 9
Press Settings.
Step 3 of 9
Press Wireless and network.
Step 4 of 9
Press Bluetooth settings.
Step 5 of 9
Press Bluetooth to activate Bluetooth.
Step 6 of 9
When the box next to the menu item is ticked (V), Bluetooth is activated.
Step 7 of 9
Press Scan devices.
Step 8 of 9
Your mobile phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
Press the required Bluetooth device.
Follow the instructions on the display to connect the Bluetooth device to your mobile phone.
The new device is displayed on the list of paired devices.
Step 9 of 9
1. Find "Bluetooth settings"
Press Applications.
Press Settings.
2. Activate Bluetooth
Press Scan devices.
4. Return to the Home screen
Customer Center
