    Samsung Galaxy S III
    How to connect to a WLAN
    You can use WLAN as an alternative to the mobile network to connect to the Internet. Your mobile phone doesn't use data traffic when connected to a WLAN.
    Step 1 of 8
    Press Apps.
    Step 2 of 8
    Press Settings.
    Step 3 of 8
    Press Wi-Fi.
    Step 4 of 8
    Press the indicator next to "Wi-Fi" to activate the function.
    Step 5 of 8
    When the indicator turns green, WLAN is activated.
    Step 6 of 8
    Press the required network.
    Step 7 of 8
    Follow the instructions on the display to key in security settings.
    Press Connect.
    Step 8 of 8
    1. Find "Wi-Fi"
    Press Apps.
    Press Settings.
    Press Wi-Fi.
    2. Activate WLAN
    3. Connect to a WLAN
    Press Connect.
    4. Return to the Home screen
